Cannot connect to my printer i3Mk2s
Aizu3DP
(@aizu3dp)
Hi all,
I am having trouble connecting to my printer to update the firmware. I keep getting this error message. [see below] I am not connect to the printer via any other software so the com port should be open.
Thanks in advance.
[avrdude.exe: ser_open(): can't open device "\\.\COM3": Access is denied. avrdude.exe: ser_drain(): read error: The handle is invalid. avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: ser_send(): write error: sorry no info avail avrdude.exe: stk500_send(): failed to send command to serial port avrdude.exe: ser_recv(): read error: The handle is invalid. avrdude.exe: stk500v2_ReceiveMessage(): timeout avrdude.exe: stk500v2_getsync(): timeout communicating with programmer avrdude.exe done. Thank you.}\]
Publié : 09/10/2017 6:55 am
3d-gussner
(@3d-gussner)
Reputable Member Prusa-Translations
Re: Cannot connect to my printer i3Mk2s
Hi all,
Thanks in advance.
Hi Phillip,
what OS do you use?
Could you upload the firmware in the past? If so did you compiled it yourself, and used the Firmware.ino.with_bootloader.rambo.hex?
can you connect to your printer via Pronterface?
Publié : 11/10/2017 7:14 am
