Add ability to add photo to top layer of 3D print in PE Slic3r?
david.b14
(@david-b14)
It would be cool if there was the ability to add a photo to the top layer of a 3D print in a future version of PE Slic3r:
More info:
https://www.velocitypainting.xyz/blog/
https://www.velocitypainting.xyz/gui/download.html
https://www.reddit.com/r/3Dprinting/comments/5uf66s/this_is_velocity_painting_created_by_mark_wheadon/
Respondido : 02/05/2017 10:11 pm
phil.s2
(@phil-s2)
Re: Add ability to add photo to top layer of 3D print in PE Slic3r?
have you checked out what the zmorph can do
you will need more than one nozzle but....
https://best3dprinter.stan-tech.com/what-is-the-zmorph-3d-printer-more-than-just-a-printer
helping others with 3d printer problems
building 3d printers
showing you can repair almost anything with a 3d printer and innovation - well, design!!
www.best3dprinter.stan-tech.com
Respondido : 03/05/2017 5:23 pm
Starlynk
(@starlynk)
Not really sure that Slicer PE would be the right place to add a photo image. That would require the ability for it to add layers to an existing STL file along with the addition of additional input for dimensions, layer heights, bump mapping, etc.
If you want to add a photo/image to an item before slicing, it would be best to use another program that is designed for that ability due to the amount of variables and changes it would have to make so the existing file.
Respondido : 04/05/2017 6:25 pm
