Ziptieing Endstops
Hi, I recently ordered a Prusa i3 Plus Kit and have started to assemble it. I'm stuck on Step 27-29 of the Y-Axis ( https://d17kynu4zpq5hy.cloudfront.net/igi/prusa3d/ETDtqUrsqhJQPChG.huge ) since I can't run the cable tie through both of the attached holes. The bottom hole is too small to fit through so I can't use it to secure the switch ( http://imgur.com/O3P4rXn,jjne0sa#0 and http://imgur.com/jjne0sa ) Has anyone encountered the same problem or have any solutions?
Veröffentlicht : 02/07/2015 9:02 pm
Re: Ziptieing Endstops
Hi, it is a tight fit, you can gently use the included nose needle pliers to help it 🙂
Founder and owner / Majitel a zakladatel
Veröffentlicht : 02/07/2015 9:06 pm
Oh ok thanks for the help! I was able to tug it through using the pliers and a drop of grease.
Veröffentlicht : 02/07/2015 9:17 pm
