Z-Screw Covers (Step 4 Z-Axis assembly)
StephanK
(@stephank)
In step 4 of the Z-Axis assembly ( http://manual.prusa3d.com/Guide/4.+Z-axis+assembly/106 ) 2 plastic nut like things referred to as z-screw covers are used. One of them fits so loosely, i simply falls down and sits there. The other one is so tight, if i screw it all the way down, i can't move the Z axis manually when powered off.
What's the point of these?
What should be the proper.. uh.. fit for these? Do i reprint the loose one or do I scrape out the tight one to be more loose?
Thanks for any input
Posted : 21/10/2016 8:45 pm
simon.p
(@simon-p)
Re: Z-Screw Covers (Step 4 Z-Axis assembly)
It should be tight like the second one and you screw it almost all the way down. Just so far as it does not touch anything. It is a dust cover so your motor bearings stay clean.
Posted : 22/10/2016 12:13 am
StephanK
(@stephank)
I will reprint the loose one then.
Thank you!
Posted : 22/10/2016 12:32 am
