Z-height problem while printing PETG
bejotto
(@bejotto)
Hello,
I was printing PLA(210/50) without any issues for more than half a year. Now I switched to PETG(230/60) and have huge problems.
I have MK2S with PINDA without thermistor. Due to higher bed temperature I first do the mesh bed leveling while cold, home the nozzle and then heat up the bed/nozzle not to disturb the PINDA measurements
With PLA I had live Z -440um, after few calibrations for PETG I ended up to 0um and the result was:
The result is as seen, the nozzle at printing intro line was so close that it did not print it completely..
I then set to PINDA probe little bit lower, since 0um was not enough..
Manual says that the distance of PINDA should be as the height of a middle part of zip tie, I did it as the end of zip tie (~1/2 lower)
I did the XYZ calib. in the room temperature
The result is as follows:
Can you please help me explain what the heck is wrong?
I calibrated XYZ while PINDA was cold, did the mesh bed leveling before print while PINDA was cold.. does my heatbed bend while it's hot?
Publié : 10/02/2018 2:43 pm
AJS
 AJS
(@ajs)
Re: Z-height problem while printing PETG
Yes. The bed is constrained at the screw points to a (not hot) mount. As it expands with temperature, it will bend and warp. This is why the Z calibration is done at the beginning of the print with the bed at temperature. The XYZ calibration is really for skew and non-parallelness. It can be done cold.
It is normal to need a different Live Z for different bed temperatures.
Publié : 10/02/2018 7:03 pm
bejotto
(@bejotto)
You're so right! Thank you.
I tried the Z calib. while bed is hot and it's perfect now 😆
Publié : 11/02/2018 1:42 am
