Z-axis moving in opposite direction
tung.h
(@tung-h)
Hi, I just completed assembling the printer. I had an issue before I can do my calibration and testing. When I go to the LCD and try to move the Z axis, the left side and right side will move in opposite direction. For example, the left side motor will turn to move upward, but the right side motor turns to move downward. Please help to resolve the issue. Any help is appreciated. Thanks.
Napsal : 22/04/2016 3:04 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Z-axis moving in opposite direction
Hi
One of the Z-motor connectors is wrong way around at the RAMBo end.
Peter
Napsal : 22/04/2016 3:07 pm
tung.h
(@tung-h)
That fixed the issue. Thanks a lot. All cables have to go in this order from the top: Black, red, blue, white.
Napsal : 25/04/2016 12:03 am
