Z axis issue
Droidgurl
(@droidgurl)
Z axis issue
Hi All!
I just finished building my MK2 upgrade and was having some problems with the Z axis during calibration.
When I run the self-test the z axis does not stop lowering and jams into the heat bed until I turn off the printer. I went through the instructions several times to see if I missed an end stop, but there does not seem to be one for the Z axis. Have I missed something?
I have successfully loaded the new firmware and everything else seems to be working.
Thanks in advance for the help!
Christina
Respondido : 23/07/2016 5:05 am
Mike
 Mike
(@mike-17)
Re: Z axis issue
I had a similar issue at first and it turned out that my P.I.N.D.A probe was a bit too high. I'd make sure that its adjusted per the documentation.
Respondido : 23/07/2016 5:20 am
Droidgurl
(@droidgurl)
Re: Z axis issue
I double checked the PINDA and it still does it. I've raised it and lowered it. I have it exactly lined up with the wire hook as the instructions say now. Is there anything else that could cause this?
Respondido : 23/07/2016 6:56 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Z axis issue
Did you run the self test? this will check the end stops.
As suggested the probe may be positioned incorrectly or the Y axis may be too far back/forward such that the probe is missing the bed insert (marked with a dotted circle).
Ensure the bed is hitting and triggering the Y endstop hen moving back. Ensure the probe is connected properly to the RAMBo (the probe is the Z end stop).
Peter
Respondido : 23/07/2016 10:12 am
Droidgurl
(@droidgurl)
Re: Z axis issue
Thanks for the help! I'm good now. I was misaligned.
Respondido : 25/07/2016 5:57 am
