Y-Frame holes for upgrading MK2 to MK2S
david.b14
(@david-b14)
Did anyone doing the upgrade use the hand drill part that came w/ the upgrade kit?
I am thinking about using a drill press and I am looking for an all 3D printable drill press like the one below, any other suggestions?
https://www.myminifactory.com/object/pillar-drill-562
Opublikowany : 27/05/2017 3:20 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Y-Frame holes for upgrading MK2 to MK2S
Yes, I used the supplied tool. A lot simpler than trying to make it complicated...
Peter
Opublikowany : 27/05/2017 6:06 pm
david.b14
(@david-b14)
Good point. I was concerned that the drill bit may break off or get stuck.
I will give it a try with the included tool after I print the new parts.
Opublikowany : 31/05/2017 3:49 pm
PJR
 PJR
(@pjr)
David
It's not hard/tight; just a matter of removing some paint and a very small sliver of aluminium.
Peter
Opublikowany : 31/05/2017 5:34 pm
