y carriage touching zip tie
Hello,
The Y carriage is touching the right zip tie when it moves to the front. I've unscrewed the extrusion, flipped the aluminum extrusion over and re-tighten on the diagonal. The Y carriage is still touching the zip tie on the right side. What else should I calibrate to make the y level on both sides in the front of the machine?
Napsal : 24/02/2018 10:48 pm
Re: y carriage touching zip tie
Can you post a picture?
Napsal : 26/02/2018 9:35 am
