Y-Axis prints 1 mm to long
Hello guys,
I have a problem with the Y-axis. I want to print a cube (20mmx20mmx20mm).
The OpenSCAD code ist very easy:
cube(20);
In Slic3r are shown the right dimensions of this Cube.
But when i print the Cube X is 20mm Y is 21mm and Z is 20mm.
And every flat is rectangular to the ground.
(except the top side. The top side is parallel to the ground)
What did i do wrong ? How can i fix the mistake?
Thank you,
Sebastian
Respondido : 13/01/2017 6:27 pm
