Y axis bearings are very loose
Dbswans75
(@dbswans75)
how long should liner bearing last not evena couple spools threw the printer yet and my bed is very sloppy and yes they are secured tightly to bed
Opublikowany : 13/03/2016 8:53 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Y axis bearings are very loose
Hi Dale
Mine have been in place for about 5 months now with almost 24/7 printing and no play on the Y chassis.
I believe they are of Chinese origin and therefore the quality may be quite variable. I do consider the bearings as consumables and have about 30 bearings in my spares cupboard (I also have a Chinese clone which goes through bearings very quickly).
Peter
Opublikowany : 13/03/2016 9:05 pm
Dbswans75
(@dbswans75)
Ty sir I will order some spares just seems premature failure for printer twice the country st of the clones otherwise love this printer !
Opublikowany : 14/03/2016 2:29 am
PJR
 PJR
(@pjr)
Hi Dale
I agree that it is very premature wear. Just a thought: are the ends of the Y-axis belt aligned properly (the idler and motor)? If one or both are slightly out, then it could induce such wear.
Peter
Opublikowany : 14/03/2016 9:15 am
