XYZ Calibration Fail, HELP!
naomi.p
(@naomi-p)
Hi, I just built my mk2 printer and I've been having some issues calibrating it. The printer is able to self test just fine, but when I try and do the XYZ calibration it never gets past the 3rd point on the four point calibration and when it is trying to do the 3rd point the PINDA hits the hotbed and will continue to move across it damaging the board. I've tried EVERYTHING, moving the frame around, moving the PINDA, taking the hotbed of and setting it back on. I would greatly appreciate any advice. Thank you so much in advance.
Publié : 13/02/2017 7:43 pm
ryan.c4
(@ryan-c4)
Re: XYZ Calibration Fail, HELP!
After you pass the self test do a auto home under calibration and take a picture of where your probe lands in relation to the circle "target"
Publié : 16/02/2017 3:29 am
naomi.p
(@naomi-p)
sorry i didn't say this before but i was able to fix the problem. It was because my screws were too tight on the heatbed and the ball bearings were off. Along with a couple of alignment issues 😆 Thanks so much for the help tho
Publié : 16/02/2017 3:22 pm
