XYZ calibration error
When I try to calibrate the XYZ it stops at the first point and says "XYZ calibration failed. Bed calibration point was not found." The part I don't understand is that Z calibration, which used all nine points, works perfectly. Am I using a bugged version of the software?
Veröffentlicht : 26/07/2017 2:24 am
Re: XYZ calibration error
It is possible that your PINDA is set a bit too high. It should be about 0.6mm higher than the nozzle (about this thickness of a credit card.) Try adjusting it and try XYZ calibration again.
Veröffentlicht : 28/07/2017 4:46 am
