X axis software binding
nathan.w
(@nathan-w)
Statuses:
Firmware - 3.0.9
Selftest - All OK
XYZ Calibration - "X/Y Skewed severly. Skew will be corrected automatically"
Preheat - PLA
Print from SD Card - V2Calibration.gcode
Printer begins calibration, gets first point, then either 2nd or 3rd point it doesn't move far enough, fails to hit a calibration point and "Bed levelling failed..."
Video:
Opublikowany : 31/12/2016 9:11 am
StephanK
(@stephank)
Re: X axis software binding
Looks to me as if the x-motor pulley might be lose?
Is the small grub screw inside the pulley tightened against the flat side of the motor shaft?
Opublikowany : 31/12/2016 8:39 pm
nathan.w
(@nathan-w)
So forgive my ignorance, but I don't see why the x-axis hardware would be the issue since it worked fine for calibration. However, since it was asked for, I double checked it, and also slightly tightened the idler as I had it somewhat loose due to https://www.reddit.com/r/3Dprinting/comments/5el9vm/prusa_i3_mk2_xaxis_not_moving_extruder_carriage/ seemingly being close, but now I get "XYZ Calibration failed. Bed calibration point was not found."
Opublikowany : 01/01/2017 3:43 am
StephanK
(@stephank)
I don't have a sound explanation either, its just something I ran into myself. I had a pulley slip occasionally - usually later in the print. So it would pass calibration and even the first couple layers and then slip.
I guess something else to check is if the carriage moves smoothly with power off (or belt removed). Given the sad state of the bearings i received in my kit, that could cause binding as well. (But yours sounded pretty good in your video).
Opublikowany : 01/01/2017 4:35 am
nathan.w
(@nathan-w)
Ok, so it WAS jerking along while powered off, all I did was loosen the motor and pulley to see if it was the belt or the smooth rods, it moved smoothly without the belt, so I tightened them back on and now it at least prints, and now I've just got printing issues (not sticking to the bed, etc) but we're in the right direction!
Opublikowany : 01/01/2017 7:39 am
nathan.w
(@nathan-w)
Apparently after getting the first layer settings mostly down, I feel something...
...and I feel...
...2017 is the year of the bat.
Opublikowany : 01/01/2017 11:56 am
StephanK
(@stephank)
There ya go.. Lookin much better.
(I think you could lower the nozzle a tiny bit more btw. Looks like it has some gaps still. I prefer the 1st layer solid and a little squished)
Opublikowany : 01/01/2017 2:04 pm
