X Axis Idler Bearing self destructed
Hi Folks,
My Mk1 Prusa X Axis Idler Bearing self destructed today,
does anyone know the part number?
the printer is less than a year old, is this a common failure? should I order a 'bucket load' of bearings? 🙂
Re: X Axis Idler Bearing self destructed
Hi Joan
I really do think that you were just unlucky. I have never had a roller bearing break since I started printing.
Just standard bearings; measure the width, inside and outside diameters and check out on eBay; they should be very cheap.
Or you could print your own: http://www.thingiverse.com/thing:44501 (if your printer was working... 🙁 )
Peter
hi Peter,
I am making a brass piece on the lathe as a temporary fix... hope it will last till the Mk 2 upgrade arrives.
I think the bearing is a 623zz
will order a couple for the rebuild.
Hi Joan
Brass is good; nice and easy to machine, but I would worry about it running on a steel thread. I think you may also need to machine a steel bush otherwise any brass swarf could end up in the Z motor.
Are the bearings not 128ZZ? Unfortunately, I can't tell at the moment, as my printer is rather busy...
Peter
EDIT: Just measured the bearings; they are 4 x 10 mm with ID of 3mm and pressed into an aluminium pulley, so I think you are correct, sorry. My other printer has simple bearings without the pulley...
Thanks Peter,
623 is 3x10x4mm which seems to be what I need for a 3mm fixing bolt and aluminium idler spool.
it was a quick fix... so I didn't over complicate the assembly! i have aluminium couplings on top of the Z motors so they will catch any droppings...
128 is 8x12x3.5mm maybe filament pressure roller?
My printer is also busy now! 🙂
Joan
The 128 is from my other printer. Getting confused, sorry..
Peter
No problems Peter,
I too have 'Senior moments'!
Joan
I think I will have the same problem on my machine too soon, the x-axis has started to sound very aggressive on movements.
I've made a short Video:
Good to know what to buy as a preparation, thanks for the lookup of the bearing 🙂
