X axis endstop
clauswilson
(@clauswilson)
X axis endstop
After assembling everything I have the problem with the x axis endstop. So it must be a wire problem. How to correct this?
Veröffentlicht : 18/10/2017 9:50 am
clauswilson
(@clauswilson)
Re: X axis endstop
Extra picture
Veröffentlicht : 18/10/2017 9:52 am
clauswilson
(@clauswilson)
Re: X axis endstop
(Had to enclose Notify me)
One solution would be to print a longer tap to hit the endstop
Veröffentlicht : 18/10/2017 9:55 am
Knickohr
(@knickohr)
Mitglied Moderator
Re: X axis endstop
Hi !
Put the cables in the right position, place it in the channels, please read documentation cerefull.
Thomas
Veröffentlicht : 18/10/2017 11:06 am
AJS
 AJS
(@ajs)
Re: X axis endstop
The problem is the wiring from your stepper motor is not routed correctly per the instructions and is blocking the motion.
See the first photo on Step 22 here:
http://manual.prusa3d.com/Guide/5.+Extruder+Assembly/295#s4995
Veröffentlicht : 19/10/2017 3:11 am
clauswilson
(@clauswilson)
Re: X axis endstop
SOLVED.
I'm now off to calibrating
Thank you for your cooperation!
Veröffentlicht : 19/10/2017 5:08 pm
