X-Axis Belt too long (MK2S build, Steps 4.17-25)
william.g19
(@william-g19)
I'm finding it impossible to meet all of these criteria:
  • The belt is supposed to be 850mm long (mine is)
  • The belt should not be sticking out of the X-Axis carriage
  • The belt should be tight when straightening the motor (ping)
  • My belt is 850mm long and I can put it in to not stick out but then the belt is very loose. I can trim the belt to make it tight but then I am not keeping the 850mm of belt (or it needs to stick out a little, like the Y-axis belt does.
    Since this is on the frame I can't think of how it is even possible that the distances aren't precise.
    Any ideas?
    Publié : 02/12/2017 5:25 pm
    william.g19
    (@william-g19)
    Re: X-Axis Belt too long (MK2S build, Steps 4.17-25)
    OK I re-read the manual and it looks like it can stick out on one side but not the other.
    So that's what I'm going with but if I have it wrong please advise. Seems like a bad spot to get it wrong.
    Publié : 02/12/2017 6:00 pm
    pjs37
    (@pjs37)
    You are correct there should be no excess on the idler side of the X-axis but a little on the motor side is fine (not like several centimeters)
    Publié : 05/12/2017 5:17 am
    I had to cut the excess of both the X and Y belts when i assmbled my printer
    Joan
    Publié : 05/12/2017 8:10 am
    william.g19
    (@william-g19)
    Thanks for both of your replies, and sorry for my late one.
    I ended up leaving a bit hanging out on the motor side and it seems to be fine (I think!). I've never seen that part go that far to the left to be an issue.
    Cheers, Bill
    Publié : 18/12/2017 11:45 pm
