Which formula of Green Loctite is best to use on the MK2 nuts and bolts holding the verticle Z-frame?
david.b14
(@david-b14)
Hello,
Which Green Loctite is the best?
Amazon sell Green Loctite in these formulations:
680, 609, 648, 290, 648, 620
Since this can be removed with "Aircraft paint remover" of which the primary ingredient was Methylene Chloride, I should go with the strongest formula. Rust-oleum has this product, https://www.amazon.com/Rust-Oleum-Automotive-255448-32-Ounce-AircrAft/dp/B003Z8XUAQ/ref=sr_1_1?ie=UTF8&qid=1479298053&sr=8-1&keywords=Aircraft+paint+remover
There is no reason to use Loctite 19269 7649 Primer N Activator, correct?
Respondido : 16/11/2016 11:52 am
jon.m
(@jon-m)
Re: Which formula of Green Loctite is best to use on the MK2 nuts and bolts holding the verticle Z-frame?
Just go to an auto store and buy a sample or small bottle of Blue lock tight from Permatex or the like. This is a printer, not an F-14. You will be fine with blue.
Respondido : 16/11/2016 11:20 pm
Omikron
(@omikron)
Actually, green is actually better for this application since green is designed to wick into threads after they've been tightened. Blue, red, purple, and others are supposed to be applied to threads before tightening, which gives a narrower window of adjustment.
Respondido : 17/11/2016 2:26 am
Nigel
(@nigel)
Lock the thread with an easily removable loctite, you may need to adjust in the future. Look up the colour or color < for the spell checker.
Nigel
Respondido : 17/11/2016 4:35 am
jon.m
(@jon-m)
Not to debate on the ins and outs of Loctite, but any will wick. Again, this isn't Aerospace standards. Blue wicks just fine and has thread creep too. Mine will never move and I applied after adjusted.
Respondido : 22/11/2016 9:08 pm
david.b14
(@david-b14)
Respondido : 28/11/2016 10:57 pm
Looks like non of them are certified for 3D
printers 🙂
Respondido : 06/12/2016 4:57 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Looks like non of themail are certified for 3December printers 🙂
Joan
Is that the phone talking again???
Peter
Respondido : 06/12/2016 5:10 pm
Yup! 8- (
Respondido : 06/12/2016 5:38 pm
