What model hotend is this?
Ben
 Ben
(@ben)
Is this the V5 or V6 please?
[attachment=1]IMG_20160903_211505[1].jpg[/attachment]
[attachment=0]IMG_20160903_211540[1].jpg[/attachment]
Postato : 03/09/2016 10:18 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: What model hotend is this?
Ben
Not certain. You need to compare with the engineering drawings. V5: http://wiki.e3d-online.com/wiki/E3D-v5_Documentation and V6: http://wiki.e3d-online.com/images/b/b5/V6-175-SINK.pdf
Peter
Postato : 03/09/2016 10:59 pm
Ben
 Ben
(@ben)
Thanks Peter. In that case it is a V6 🙂
Postato : 03/09/2016 11:06 pm
PJR
 PJR
(@pjr)
Yeah, I wasn't sure. I just had mine apart a couple of hours ago, and it looks different.
I have the early V6 and I found that the heat break was both partially blocked and bent. I had a mid-brown oily fluid on the filament whenever I pulled it; no idea what it was, but some had burnt inside the heat break.
As for the bend; I have no idea how that happened.
Peter
Postato : 03/09/2016 11:40 pm
Nigel
(@nigel)
It doesn't seem a genuine E3D V6 hotend assembly. The cooling fins seem differently spaced to my genuine sourced E3D V6 hotend assembly, (ie bought directly from E3D) used on another printer I built. The cooling fins on a genuine E3D V6 are evenly spaced.
http://e3d-online.com/E3D-v6
Watch the video.
Nigel
Postato : 04/09/2016 3:48 am
SBS
 SBS
(@sbs)
Based on E3D's one spec, the heatsink does not look like a genuine E3D V6 part.
Assembled MK2.
Postato : 04/09/2016 5:38 am
Ben
 Ben
(@ben)
It is a very good point. Thank you 😉
I had not noticed the spacing. On further investigation it is a genuine E3d but it is NOT a V6
It is actually an E3d Lite6.
Postato : 04/09/2016 8:49 am
3Delight
(@3delight)
Moderatore Moderator
Definitely the Lite model Ben, that's what came with the Prusa MK1 1.75mm Printer, the MK2's (assembled, kits and upgrade kits) come with the V6 Full version...
The Lite has uneven spacing and the profile is a sort of wave shape...
Postato : 04/09/2016 4:58 pm
