Weird swirling problem?
tyler.s
(@tyler-s)
I've been having this weird issue pop up every now and then where the printer somehow manages to make swirling patterns in my prints, thus ruining them. I'm assuming it's a simple dust clog because my room can be pretty dusty, and whenever I cold pull it fixes the problem as well as removes dirt. However, the pattern is what makes me think it could possibly be a firmware glitch. Idk why the printer would create this spiral if the problem was just a clog. Maybe someone could explain it to me.
I use simplify 3D as my slicer, but I don't think this is the issue because I've had this problem before and I was able to get both a failed print and a successful print from the same file.
https://drive.google.com/open?id=0B1cqcma1i_VHN0NlT0ZJT0tPZ1k
https://drive.google.com/open?id=0B1cqcma1i_VHZWpkV3VFVDZkaVU
Napsal : 06/06/2017 8:05 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: Weird swirling problem?
seems like a problem with missing support structure, which sometimes lets you drop down a layer at the edge of a structure.
try to increase the temperature a little bit and the fan.
Napsal : 06/06/2017 9:38 pm
