Unexpected issue after turning printer off
alex.c3
(@alex-c3)
Hello all
I turn my printer fully off after I'm done using it to conserve energy and keep the screen from keeping me up at night (The printer is in my bedroom). Anyway, every time I turn the printer back on, it seems that the Z-axis calibration has reset, and it's quite annoying to recalibrate the Z axis every single time I want to use the printer when I get home from work. Is this normal or is their something wrong with my printer? (everything that was "wrong" with my printer so far has been my fault, so I was curious if this was also the case)
Thanks!
Postato : 13/11/2016 3:25 am
simon.p
(@simon-p)
Re: Unexpected issue after turning printer off
what do you mean with your z-axis calibration is reset?
Postato : 13/11/2016 11:07 am
Omikron
(@omikron)
I'm guessing he means that his live-adjust setting is reset, or that the printer keeps displaying "the calibration needed" message.
Postato : 13/11/2016 7:11 pm
Nigel
(@nigel)
Did you turn off your printer after the final cooldown? If not that way may lead to filament clog. The loss of settings is a failure of saving settings.
Nigel
Postato : 14/11/2016 5:40 am
alex.c3
(@alex-c3)
Merv, I'm assuming final cooldown is when the printer reaches the same temperature as the room it's in, in that case, yes. Does the printer save settings automatically or does it need to be saved manually?
Omikron, Correct, it does show the "Calibration needed" message.
Postato : 15/11/2016 3:04 pm
simon.p
(@simon-p)
did you run the v2calibration gcode?
Postato : 15/11/2016 4:27 pm
alex.c3
(@alex-c3)
I believe I did but I can run it again just to be 100% sure
Postato : 15/11/2016 5:02 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Alex
Ensure that the V2Calibration runs to the end; don't cancel the print at any time.
Peter
Postato : 15/11/2016 5:29 pm
alex.c3
(@alex-c3)
Alex
Peter
The V2Calibration ran perfectly fine
Postato : 16/11/2016 12:48 am
alex.c3
(@alex-c3)
Yes, I did run the V2Calibration gcode. Ran perfectly fine.
Postato : 16/11/2016 1:04 am
Nigel
(@nigel)
Oops forgot to say run the latest v2calibration gcode. After . That may help.
Nigel
Postato : 17/11/2016 4:32 am
alex.c3
(@alex-c3)
I'll download it and run it when I get home. I ran the one that came with my printer and it changed nothing, just FYI.
Postato : 17/11/2016 2:20 pm
JohnnyricoMC
(@johnnyricomc)
It will probably indeed be the v2calibration.gcode on your suppliad SD card being older than the one needed to disable that message.
Postato : 17/11/2016 3:10 pm
alex.c3
(@alex-c3)
Will that also solve the issue of Z-Calibration resetting every time I completely power down the printer?
Postato : 17/11/2016 7:30 pm
JohnnyricoMC
(@johnnyricomc)
Yes. What happens is: the most current v2calibration.gcode contains a G-code command which will tell the firmware to reset the flag which causes the message to appear.
If you're curious, vojtěch.b3 has a more in-depth explanation: http://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/new-3-0-8-firmware-released--t1642-s20.html#p12786 and
Postato : 17/11/2016 8:34 pm
alex.c3
(@alex-c3)
Alright, I'll do that when I get home. Seems pretty easy as well!
Postato : 17/11/2016 9:08 pm
alex.c3
(@alex-c3)
I don't know if the Z-Axis is meant to go to Zero every time the printer is turned off and on again, but here's what I'm seeing on my side.
https://drive.google.com/open?id=0B6lsaKH21bZOR1dFcG1DN281T28
Here's a video I took of everything I did.
Postato : 18/11/2016 1:50 am
