Uneven layer width issue
ian.m5
(@ian-m5)
Hi guys,
Yesterday I printed a new phone holder to use in my car. Fitment was perfect but I noticed the two small walls are of uneven thickness.
So I thought it might had something to do with nozzle temp.
I made a temp calibrating tower first 1 shell thick then 2 shells thick. The single shell tower looks flawless:
I could hardly see any difference in temp changes from 215 to 175.
I then decided to do a 2 shell tower and here is where it gets interesting. Looking closely you can see half way up every 15mm the gloss turns more matte around 190 and lower temps:
Ghosting is almost completely absent:
The single shell wall showed much more ghosting, but I never intend to use 1 perimeter for walls. And the little protrusions on the corners are from the file itself. I could see them in Repetier Host I used for the temp change per every so many layers.
What these temp towers showed me that every layer is the same width and tells me that I calibrated the extruder stepper and filament diameter near perfect, right? So I don't understand why the model I printed to hold my phone is showing slight imperfections in thickness. I assume this has something to do with the infill an how much the layers overlap.
What do I need to change in Slic3r to get rid of this?
here are my Slic3r settings:
Infill is 20% and cubic/rectilinear
Publié : 23/04/2017 7:11 pm
ian.m5
(@ian-m5)
Re: Uneven layer width issue
Slicing previews:
Publié : 23/04/2017 7:17 pm
