underextrusion after update to 3.0.11 and to MKS upgrade
tomas.k
(@tomas-k)
Hello folks,
I have problem after I proceed with upgrade to MKS and update to 3.0.11. During print ABS, Nylon, CF20, PLA or HIPS on the top solid layer are holes cca 3mm in diameter it looks like problem with extrusion. Gear on motor is tighten well (was not moved since i build it) and checked it twice. Somebody of you have same issue?
Tomas
Posted : 28/05/2017 7:41 pm
gkol
 gkol
(@gkol)
Re: underextrusion after update to 3.0.11 and to MKS upgrade
So you have to do an extruder calibration.
Posted : 28/05/2017 9:17 pm
tomas.k
(@tomas-k)
Done, I asked 20mm I got 20mm. But still I see those holes on print. I possible to download release 3.0.10?
EDIT: I found older release: http://prusa3d.com/downloads/
Posted : 28/05/2017 9:32 pm
