Under extrusion or wrong z-hight?
casper.k
(@casper-k)
I am in the process of setting up my mk2s kit and it has been full steam ahead until now, I am not sure what I'm doing wrong.
It's hard to explain so i will show these two pictures instead:
http://imgur.com/O4uL1w0
http://imgur.com/W52OBcn
Is the extruder set wrong?
What can i do to start improving my print?
Postato : 10/08/2017 1:20 pm
Cdanna76
(@cdanna76)
Re: Under extrusion or wrong z-hight?
Try this post, it looks like you may have to adjust your Z height.
https://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/life-adjust-z-my-way-t2981.html
Postato : 10/08/2017 2:01 pm
JeffJordan
(@jeffjordan)
Utenti Moderator
PLEASE don't use the "Img" function of the board-software and links to online picture hoster to insert pictures into your post !
attach them as *.jpg file instead. 😥
why ? ❓
➡ because this forum should be a knowledge base where users can learn from other users. if they parse over such a post in a year or two, it's very likely that the online folder that previously holds the pictures, won't be available then.
if you attach the pictures to your posting, they will be stored at the prusa server and so will be available as long as it lasts here...
💡 :mrgreen: 💡
Postato : 10/08/2017 3:07 pm
