Unable to calibrate
Got kit in January. Successfully assembled the Kit - ran self-test successfully - ran XYZ-calibration - calibration failed. Reran calibration several times - it failed every time but each time in a different way - but always when trying to calibrate the x-axis. It acts as if the bearings are causing friction so the step motor does not go as far as it thinks it does and tries to find the calibration point in the wrong location.
Napsal : 13/03/2017 3:24 am
