Unable to calibrate
andrew.l7
(@andrew-l7)
Unable to calibrate
I have just finished building my kit and have turned it on for the first time.
The message "Printer has not been calibrated yet, please follow ...." comes up. I press the "Enter key and it reveals the Status Menu. Pressing again reveals the main menu on which I try to access the Settings options. However, the screen just fills with dot matrix squares and repeats the message "Printer has not been calibrated ...."
Am I being stupid, or is there a problem somewhere?
Thanks,
Opublikowany : 25/05/2017 8:20 pm
Filip Safran
(@filip-safran)
Re: Unable to calibrate
You ahould go into the Calibration menu, not the Settings menu
Opublikowany : 25/05/2017 10:17 pm
andrew.l7
(@andrew-l7)
Thanks but that is the problem - I cannot go into any sub-menu.
Opublikowany : 25/05/2017 10:26 pm
Filip Safran
(@filip-safran)
Hmm... Can you take pictures of each step as you turn it on? Ive been using mine for two days, so Im not an expert in any way, but it was pretty straightforward for me to calbrate it.
Opublikowany : 25/05/2017 10:30 pm
andrew.l7
(@andrew-l7)
Filip,
How about a video:
https://drive.google.com/open?id=0B3M24U-aiQw9bjB2dTlYTEx6dzA
Thanks,
Opublikowany : 25/05/2017 10:56 pm
Filip Safran
(@filip-safran)
Oh, I completely missed your point in the openning post, sorry.
I'd leave this to someone more knowledgable of electronics than me, it seems there's a hardware problem.
Opublikowany : 25/05/2017 11:05 pm
andrew.l7
(@andrew-l7)
Filip,
Okay, thanks anyway.
Opublikowany : 25/05/2017 11:09 pm
kevin.r5
(@kevin-r5)
Looks like it's not detecting the SD card either.
Check the connection of the ribbon cables from the LCD at the Rambo board. The red stripes on the cables should be facing the top of the Rambo board. Also make sure the cables are not shifted up or down by 1 pin.
Also check the routing of the ribbon cables, I've read that they're susceptible to interference.
-Kevin
Opublikowany : 25/05/2017 11:20 pm
andrew.l7
(@andrew-l7)
Kevin,
I will thanks, tomorrow. I need to sleep after that construction session !!
Opublikowany : 25/05/2017 11:40 pm
