Turning 'OFF' the Prusa i3?
russ.j2
(@russ-j2)
I'm a little embarrassed to ask such a basic question (especially after all this time), but how do you turn off or shutdown the Prusa i3? I noticed that there is a little black button on the RAMBo mini, but that just seems to serve as a reset. I also tried the following sequence through the LCD panel: Prepare > Switch power off, but that does that does not work either. And I tried pressing the 'X' button on the panel below the controller, but the screen will briefly clear and then return to its regular status. Or - is it simply unplug the power supply?
Napsal : 27/08/2015 1:15 am
Hitman13429
(@hitman13429)
Re: Turning 'OFF' the Prusa i3?
On mine that I put together last night there is a on/off switch on the power supply. I just flipped that switch and kept it plugged in.
Napsal : 27/08/2015 7:10 pm
Josef Průša
(@josef-prusa)
Member Admin
We started to put the switches on the PSUs just a few days ago. Best way is to use extension cord with a switch on it.
Founder and owner / Majitel a zakladatel
Napsal : 27/08/2015 11:31 pm
russ.j2
(@russ-j2)
Ok thanks - no problem. I just wanted to be sure I wasn't missing something.
Napsal : 28/08/2015 9:39 pm
