"This printer has not been calibrated yet" will not go away after upgrade 3.0.8
Just upgraded to 3.0.8. I followed the calibration flow, yet after printing the calibration and setting the z-height I still get this message each time I reset or power up. Other than making a minor PINDA probe adjustment (getting close to -1). Also XYZ cal is successful, but reports OK but "slightly skewed".
Selftest passes with no issue.
Everything else passes cal with no issue.
I assume the calibration process writes the cal values somewhere on the controller.
What am I missing?
Thanks in advance!
jim
Re: "This printer has not been calibrated yet" will not go away after upgrade 3.0.8
Hi Jim
Can you post a picture of the printer?
You need to run the latest version of the calibrationV2 (it need to contain the G87 gcode witch remove the message)
Thanks figured out that I was aborting the print a little too soon
Glad to hear it's resolved.
However, you should not cancel the v2calibration before the end.
V2Calibration is a good way to see if the first layer is equally squished on all the bed.
Hi
I had the same problem. It only disapered when i fully printed a new object with the new slicer update. I guess it includes the G87 code 🙂
Just for info tho
