The filament is not absorbed by the extruder
Good afternoon when trying to print I realize that the filament is stuck and the printer is still doing the printing process but it is not making the layers of material and it is heard that something is thundering inside. Has anyone gone through the same? I need to know what is happening and if I can solve it. Thank you. 😭
I have 250 hours of printing and I have already changed the nozzle once.
Postato : 30/09/2019 8:37 pm
RE: The filament is not absorbed by the extruder
Unload the jammed filament and post a photo of the melt end.
If it looks like the above, there is a fix if you aren't using an MMU.
Or it can be as simple as not enough tension on the idler adjustment screw, or the axle of the idler gear not fully engaging both of the supports on the door.
Questo post è stato modificato 7 years fa da --
Postato : 30/09/2019 10:12 pm
1 persone hanno apprezzato
