Test print and more experienced advice wanted
mick
 mick
(@mick)
I made a little test board last night and ran the print to see how it managed. There is a few errors on it that i literally do not have the experience to diagnose so i am hoping some more experienced folk on here can help.
I can see errors in some of the round parts and general errors on layers i have never seen before so i am keen to get this diagnosed. Before the bearings issues my prints were flawless pretty much.
I have attached some pictures and hope they are detailed enough to help.
?dl=0
?dl=0
?dl=0
?dl=0
?dl=0
?dl=0
?dl=0
?dl=0
Thanks
Mick
Postato : 08/02/2018 2:05 pm
mick
 mick
(@mick)
Re: Test print and more experienced advice wanted
I am printing a 100mm high tube as we speak to test the vertical aswell
Postato : 08/02/2018 3:01 pm
mick
 mick
(@mick)
And here is the vertical print. It looks perfect except for a line that runs all the way down it?
?dl=0
?dl=0
?dl=0
?dl=0
Postato : 08/02/2018 5:31 pm
AJS
 AJS
(@ajs)
The small pumps on the original and the seam on the cylinder are all the seams where the printer changed layers.
You can move them in Slic3r here: Print Settings -> Layers and Perimeters -> Advanced -> Seam position Set it to random to minimize the visual effect.
If you do external perimeters first you will get worse overhangs, but better surface finish.
Postato : 09/02/2018 3:52 pm
