Stop print = Break my printer?
jordan.c
(@jordan-c)
So today I stopped a print for the first time via the lcd (not octo print) and as soon as I clicked it, the bed rushed forward, slammed into the left foot (stopper?) and the belt skipped a dozen or so teeth.
Ummm.... never doing that again. What the hell happened? It was almost like it was in relative mode.
Opublikowany : 20/01/2017 4:18 pm
David T.
(@david-t)
Re: Stop print = Break my printer?
fw version?
Opublikowany : 20/01/2017 5:08 pm
PU2
 PU2
(@pu2)
Time to time I have similar problem - in this case (I expect it) and immediately push reset button. It seems be FW problem.
Opublikowany : 20/01/2017 5:40 pm
patrizio.b
(@patrizio-b)
Indeed a fw problem, happened various times. Never use the printer again after a stop: reset or power cycle first.
Opublikowany : 20/01/2017 7:03 pm
jordan.c
(@jordan-c)
fw version?
3.0.9
Opublikowany : 20/01/2017 8:10 pm
mavu
 mavu
(@mavu)
fw version?
3.0.9
Interesting, I never had that, and am using 3.0.9 too.
Are you using slic3r? or some other slicer?
Opublikowany : 21/01/2017 11:09 pm
jordan.c
(@jordan-c)
fw version?
3.0.9
slic3r but this is outside of that scope... it has to be a firmware thing right?
Opublikowany : 22/01/2017 12:37 am
JeffJordan
(@jeffjordan)
Member Moderator
quite curious.
because i'm often experimenting and testing, i often stop the print via the lcd console.
did it at least between 30 and 40 times, but i never had the described problem.
btw. my MK2 runs with firmware 3.0.9 too, but my octoprint is NOT connected to the printer... it's only installed for providing the little endoscope cameras video stream.
so the prusa is completely "stand alone".
Opublikowany : 22/01/2017 1:28 am
MichielvH
(@michielvh)
Had the same problem a few times here also. FW version = 3.09.
Opublikowany : 22/01/2017 8:20 pm
JeffJordan
(@jeffjordan)
Member Moderator
@m.j.w..v: is your printer connected to a raspberry with octoprint, or to your computer ?
Opublikowany : 22/01/2017 8:28 pm
MrMik
(@mrmik)
Same problem, also affects Z-axis at times.
FW 3.0.9, not sure if it also happened with 3.0.8 but I think it did.
This work around works for me most of the time:
"Pause Print" first, wait until extruder stops moving. It can take a while. The "Stop print" > "YES".
If you stop the print when the extruder is not moving (during preheating for example), then wait 20-30s after "Pausing".
Opublikowany : 22/01/2017 10:33 pm
jordan.c
(@jordan-c)
Yeah... it is.. you think this happens when canceling a print started by octoprint?
Opublikowany : 23/01/2017 3:07 pm
JeffJordan
(@jeffjordan)
Member Moderator
i had some issues here when i connected my i3/mk2 via usb to the octopi. main problem is that if you connect/reconnect the port, the rambo does a reset.
it's only an assumption that the mystic behaviour of the printer is related to the raspberry connection, but an educated one ;-).
Opublikowany : 23/01/2017 3:36 pm
Carsten
(@carsten-2)
I print via Octoprint and had never such a strange behaviour. And I canceled more than often a print 😳
Carsten
My Prints: https://www.prusaprinters.org/social/15695-carsten/prints
My Employer: https://make-magazin.de
Opublikowany : 23/01/2017 8:07 pm
jordan.c
(@jordan-c)
solved
It was a bug when you cancelled a print before homing. I only just noticed this because of the release notes for the next frimware version
Stopping print before homing happened and axis positions were known could led into crashing. It has been fixed and stop print sequence now contains no movements in X or Y direction unless axis positions are known.
https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.0.10-RC1
really glad we weren't crazy and they fixed it
Opublikowany : 10/02/2017 11:26 pm
