Small dents? What is the reason
ZARIBO
(@zaribo)
Mostly my print results are good but I just want to know if it is possible to make them perfect.
As seen in the pictures there are small dents happening and really cant understand the reason. Looks like the extruder moves slightly more instead of it should stop a point. Dont know if I described the issue well but as I said it is shown on the pictures.
Belts are tight. Calibration is perfectly ok.
Publié : 09/01/2017 11:28 pm
Re: Small dents? What is the reason
hI Murathan,
these look like layer start / finish points
if you slow down the print speed and watch the layer statr finish points you may be able to identify whether this is an issue at the beginning of the layer, or the end of a layer.
then we can look ar ways to resolve the marks.
regards Joan,
Publié : 10/01/2017 2:57 am
ZARIBO
(@zaribo)
Can't say if it is a start or a stop. As you see in the pictures those red lines intersections causing those dents. I am using the FFF settings provided by Joseph for MK2.
And as you see there are no dents on the first big ring at the bottom. Dents are on the cone shape.
Publié : 10/01/2017 7:38 am
Matt3o
(@matt3o)
maybe a little over-extrusion try to reduce the flow. you may also try the settings I'm recently testing. I've got very good results with those:
https://gist.github.com/cubiq/502e171c6ee0f69f47044dbabace829b
Publié : 10/01/2017 10:41 am
ZARIBO
(@zaribo)
Many thanks, I will give it a try...
Publié : 10/01/2017 5:42 pm
