Slic3r generating banding using prusa profile?
kniski
(@kniski)
I've been trying to print out a good benchy and my results from slic3r made me wonder if my printer is ok. The first print had severely misaligned layers, the second has a bunch of banding:
In both images the slic3r boaty is on the right. The leftmost grey one was printed at 120mm/s using cura.
They were both sliced using the same version of slic3r and the same settings (.15mm optimal).
I would have thought it was a printer assembly problem, except that Cura seems to do a much better job. The cura sliced benchy suffers from some zits, but the layering looks awesome.
Has anyone had problems with that and found a solution? Alternatively, does anyone have suggestions for cura settings to remove the zits?
Also, the pre-sliced objects on the sd card look great:
Postato : 06/03/2017 2:10 am
kniski
(@kniski)
Re: Slic3r generating banding using prusa profile?
My bad, this is the picture with two benchys from cura, left one at 120mm/s center at 60
Postato : 06/03/2017 4:07 am
gabriele.s2
(@gabriele-s2)
This is what I got using Slic3r.
- Gab
Postato : 07/03/2017 2:05 am
kniski
(@kniski)
Here's my latest print using cura. The new experimental coasting setting helped to get rid of most of the blobs/zits
Postato : 07/03/2017 5:47 am
