Shift towards front after updating to 3.0.7
Nathan
(@nathan-5)
I just flashed the 3.0.7 firmware and did the Z calibration followed by the CalibrationPrint to adjust the live z value. I had to raise the nozzle after the update which is fine but what also seems to have changed is that the pinda probe is no longer lining up directly with the probe circles, at every point it is too far forward. Since the only thing I have changed is the firmware has anyone else seen this problem after doing the update.
I only did the z calibration after the update do I need to start back at the beginning of the kit calibration workflow?
Thanks,
Nathan
Opublikowany : 25/08/2016 2:18 am
Nathan
(@nathan-5)
Re: Shift towards front after updating to 3.0.7
Any ideas, I am going to try to do the entire calibration procedure tonight and see if that fixes it but I don't remember reading anything in the calibration documentation that would result in the bed being shifted.
Opublikowany : 26/08/2016 11:07 pm
Nathan
(@nathan-5)
Running the xyz calibration fixed the shift so all is good now. One strange thing is that the first time I ran the xyz calibration is came back saying the bed was severely skewed. I ran it again right after and it came back only slightly skewed. Not quite sure what to make of that but it is printing great.
Opublikowany : 29/08/2016 3:06 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
You built the printer at the threshold between "severly" and "slightly skewed". Due to the noise in the measurement, sometimes you will get over the "severly skewed" threshold.
Vojtech
Opublikowany : 01/09/2016 7:24 pm
Nathan
(@nathan-5)
I didn't build the printer, bought it assembled but since it seems to print well I don't think I am going to mess with it, unless fixing the skew is not to intrusive.
Opublikowany : 01/09/2016 7:49 pm
