Settings > Preheat > Cool down
steve.a
(@steve-a)
Hi All,
When I've finished printing do i need to select the Cool Down option and wait for it to cool down before turning off the power, or can I just power off?
Cheers
Steve
Posted : 20/04/2016 1:55 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Settings > Preheat > Cool down
Steve
At the end of a print, the heaters should be turned off automatically, so you only need to use the "cool down" option if that doesn't happen or if you have manually heated the extruder.
You should not turn off the printer until the extruder fan has stopped running (extruder < 50 degrees).
Peter
Posted : 20/04/2016 2:03 pm
