Self Test Fail - Endstops Wiring Error Z Axis
Barry
(@barry)
Just finished building my I3 MK2S , upgraded the firmware to v3.0.11 and then ran the self test.
Passes on the two fans. The Z axis starts to rise and error is given: Wiring Error Z
I've gone into the Calibration / Show End Stops. X and Y change from 0 to 1 when I operate them, but Z stays at 1 always.
I suspect a bad Pinda?
I did also check the connection on the Rambo, and it is secured. Disconnected and reconnected, just to be sure.
I have access to multimeter and oscilloscope if that can be any use in further diagnosis.
What is the pinout of the Pinda? Maybe I can test it directly.
Also tried swap of Z and Y ends top connectors on the Rambo, and problem moved to Y in calibration test. Did some cable wiggling along whole length of pinda with no change.
Veröffentlicht : 04/06/2017 1:51 am
kurt.p3
(@kurt-p3)
Re: Self Test Fail - Endstops Wiring Error Z Axis
I have the same problem on my 1 week old MK2S. But it printed fine (or at least good, lots of adhesion problems) for like 10 prints. So could the pindar probe have failed after just one week?
Veröffentlicht : 03/07/2017 9:06 pm
