Self test bed bug
MrMik
(@mrmik)
Self test bed bug
I accidentally found that there is a fault with the self test. It does not detect that the bed is not heating up and reports that the bed is OK when the 15A fuse is not inserted properly.
Opublikowany : 31/12/2016 9:55 am
richard.l
(@richard-l)
Member Moderator
Re: Self test bed bug
It will also pass the self test if the thermistor for the bed is plugged into the wrong port on the board.
Opublikowany : 31/12/2016 5:51 pm
MrMik
(@mrmik)
And it also passes the self test when the heater element for the hot-end is open circuit (broken).
See http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/preheat-error-t2104-s10.html
Opublikowany : 29/01/2017 10:04 pm
