SD Card not always recognised
If I start my i3 Mk2S with the SD card already in the socket, all is well.
If I leave the printer on, take the card out (to add a file to it) and re-insert it, the bottom line of the display reads "Card inserted". However, if I then go to "Print from SD card", that option is replaced by "No SD card".
If left for long enough, this sometimes resolves and the "Print from SD card" option returns, but usually, I have to turn the printer off and on again (after which the card is read normally).
It's irritating, rather than a major problem, but is this something that anyone else has noticed or has a fix for?
Opublikowany : 11/07/2017 9:09 am
