SCAD files wrong dimensions
AnilM3
(@anilm3)
Hi Everyone,
I've been trying to print the parts for the printer directly from the scad files, generating an STL with OpenSCAD, but after the part was printed I noticed that the holes were smaller than they should have been. I've only printed the x-end-idler and the x-end-motor parts. I checked the source code and for some reason the bearing is set to a diameter of 14.5mm and the smooth rod to 7.8.
Is there a particular reason for this? Was this intentional?
Thanks!
Posted : 13/04/2016 11:14 pm
Stefan Krister
(@stefan-krister-2)
Re: SCAD files wrong dimensions
Hi Anil,
I think it's intentional. You have to be smaller to get a tight fit for the rods. The bearing part is sliced, so it can give enough room to the inserted bearings.
Regards
Stefan
Posted : 04/05/2016 3:28 pm
warandv
(@warandv)
could you please share the stl files repository link for the Prusa kit ?
Posted : 29/06/2016 8:43 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Depends what you are looking for but it's all in here : https://github.com/prusa3d
Ensure you select the correct branch.
Peter
Posted : 29/06/2016 9:14 pm
