Reprap I3 "retraction" issue/feature
jordan.d2
(@jordan-d2)
Hi there,
I've built my first printer just last night, and after a few struggles reading the instructions, it all appears to be functioning.
I am facing an issue of some sort of "retraction" issue/feature, where it is jittering the output every 10mm or so.
https://imgur.com/a/AKfCs
Is there any way to stop this entirely? for what i would like to do, I would much rather have a consistent flow.
The settings I've played with to try and fix this was flow: 150%, speed overall 20mm/s, extruder 200c, bed 60c using cura.
Any help for a newbie would be massively appreciated.
Thanks!
Opublikowany : 07/11/2017 8:12 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Reprap I3 "retraction" issue/feature
This is an official support forum for Prusa Research s.r.o. customers.
You should contact your printer supplier or manufacturer
Peter
Opublikowany : 07/11/2017 11:31 am
in the mean time, try the Prusa Research edition of Slic3r in preference to Cura, it may help you help yourself!
Opublikowany : 07/11/2017 3:10 pm
