Replacement P.I.N.D.A nut?
gus.b
(@gus-b)
Hi everyone, newby here.
I've just built my first i3 mk2 and the first few prints (Adalinda and gear bearing) and they printed beautifully, but since then I have had a couple issues which I think are being caused by my PINDA not being properly aligned.
I managed to lose the lower nut to hold the PINDA in place during the build, so does anyone know where I can get a replacement? Or what nut it is?
Thanks 😀
Gus.
Napsal : 14/10/2016 4:44 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Replacement P.I.N.D.A nut?
Hi Gus
Yes, that would be a problem...
I believe the nut is regular M8, 12mm across flats and 3mm thick. I guess it would be possible to print one, if you had a working printer... 😮
Peter
Napsal : 14/10/2016 5:11 pm
sarah.w
(@sarah-w)
I was going to suggest using the black M8 nuts in the spares bag, but I have tested with a broken probe and the M8 nuts will not fit. I guess the threads are a different pitch.
Napsal : 14/10/2016 5:57 pm
PJR
 PJR
(@pjr)
Yeah, there are 2 pitches for M8; the probe is 1.0mm, the rods are probably coarse @ 1.25mm.
Peter
Napsal : 14/10/2016 6:23 pm
gus.b
(@gus-b)
Thanks for the help guys!
Yeah I had already tried the spares and none fitted.
I will order a new one now!
Napsal : 15/10/2016 12:34 pm
simon.p
(@simon-p)
I printed M3 nuts when I needed some. They worked just fine.
Napsal : 15/10/2016 11:43 pm
gus.b
(@gus-b)
Good idea! I will try that tomorrow.
Napsal : 18/10/2016 2:31 am
