removing nozzle issue
I was printing bamboo this week and came into see a print that was moving but not extruding. Figures it must be a nozzle jam so I followed the steps to remove the nozzle. Got everything off, heated up the nozzle to 200 but I cannot for the life of me get the nozzle off the heating block. I have a spanner wrench on the heating block and a pair of pliers to turn the nozzle just like in the instructions but the nozzle won't budge. I don't want to apply too much force as the pliers will just slip on the brass nozzle. Am I doing something stupid like turning the wrong way? I am turning to the left or counter clockwise. Sry pic below is sideways. Any suggestions would be great!
Re: removing nozzle issue
Instead of using the pliers to unscrew the nozzle, try the 7 mm spanner. It's a lot better and it won't scratch the nozzle as the pliers.
Unscrew to the left. If it's stuck, try to preheat the hotend to higher temperature like 230°C.
when i change the nozzle (did it this weekend because of a complete hotend "service"), i hold the hot (as hot as it goes) heater block with a 24mm wrench at its front and back surface (not the sides, where you got the thermistor and the heater peeking out) and use a 7mm nut to loosen the nozzle.
best would be to disassemble the whole extruder body and span the hotend with its cooler into a bench vice, while it's electronics are still connected to the rambo, like tom does in his how to video.
Thanks so much, totally worked, 7mm nut got it unstuck, funny how I couldn't do it with pliers. Any recommendations for a more robust nozzle? Is there a certain brand that most people use when printing with metal filaments that works well?
💡 look at the link that i posted above. there thomas sanladerer gives some infos about other nozzles.
furthermore there are some threads here about hardened, stainless steel and other types of nozzle.
💡 unless you are dealing often with exotic filaments (like carbon fibre), i personally would stay with the brass nozzle. it provides very good heat conductivity, suits for the most filaments and is cheap to replace.
