Reading the detail on XYZ cal measures
elliot.l5
(@elliot-l5)
I'm trying to improve my calibration because my bed isn't straight.
In the support menu, i ran the detail on XYZ cal measures and my results were'nt close to perfect.
Min y axe :
Left: 5.71mm
center: 5.62mm
Right: 5.53mm
Angle:
19 percent
I recalculated everything and im still within these ranges.
How close are you guys to perfect calibration and how do you manage to get accurate measurements?
I have a 0.01 digital caliper and i always feel stuck or unable to take proper measurements.
Publié : 30/08/2017 11:16 pm
LaPointe
(@lapointe)
French moderator and translator Moderator
Re: Reading the detail on XYZ cal measures
I never checked those values before since the XYZ calibration was telling me that my axis were perpendicular.
But I've checked for you just now and I have :
Left: 2.32mm
Center: 2.34mm
Right: 2.35mm
Skew: 0.00°
:mrgreen:
Publié : 30/08/2017 11:58 pm
slippyr4
(@slippyr4)
The only one that really "matters" is the skew angle. The others are just linear transformations which represent the variance in the X and Y endstop trigger points; these are made up from slight differences in the threaded rod lengths, microswitch mounts and so on.
Publié : 03/09/2017 9:40 am
slippyr4
(@slippyr4)
If you want to be bewildered with details, redo your calibration but from octoprint with the gcode M45 V2
Publié : 03/09/2017 9:41 am
JeffJordan
(@jeffjordan)
Membre Moderator
@my genuine i3 MK2:
Left: 1.97 mm
Center: 1.90 mm
Right: 1.84 mm
Measured skew: 0.00°
@my selfbuild clone:
Left: 1.71 mm
Center: 1.63 mm
Right: 1.54 mm
by the way: by recalcualting everything, nothing would improve. you need to correct the assembly physically.
Publié : 03/09/2017 10:15 am
