RAMBo mini LED lights
aleksandar.t
(@aleksandar-t)
Hi all, I'm new to 3D printing and I've just made couple of print tests with my new Prusa i3. So far it was great, I'm very happy with the printer and had no problems assembling it. Big thanks to Prusa team for making great assembly manual.
I have a question regarding LED lights on RAMBo board. When I first assembled the printer and turned it on all the red lights lit up, the reason was improperly plugged fuse so it was easy to fix it. After fixing only green LED on top was lit.
Now when I'm printing various red LED's light up, some flashing some steady and I'm not sure if this is normal behaviour. What LED's should be lit normally?
Aleksandar
Postato : 26/01/2016 11:30 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: RAMBo mini LED lights
Hi Aleksandar
There are quite a few LEDs on the board; in quiescent state, only the green power LED will be lit. The orange LED next to it (the status LED) displays USB comms. There are also additional LED which light when (for example) the heaters are turned on.
More info is available here: http://reprap.org/wiki/MiniRambo
Peter
Postato : 26/01/2016 12:46 pm
aleksandar.t
(@aleksandar-t)
Thanks Peter
Postato : 31/01/2016 12:57 am
