Rambo board (not mini)
David Wybourn
(@david-wybourn)
Hi All
So it appears that I've managed to damage my rambo mini board beyond repair (support were unable to find the issue), so I need to get a new one. I was wondering if the firmware and casing would work with the Rambo board (not the mini version).
The reason I ask is that the Rambo board would give me the option to upgrade to a dual extruder setup in the future.
Thanks
David
Veröffentlicht : 08/07/2016 2:10 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Rambo board (not mini)
Looks like the RAMBo is a fair bit larger than the Mini.
You would have to ensure that the pin-outs match exactly otherwise it would require amendments to the firmware as well.
Basically, I don't know the answer to your question and a whole load of research is required to answer it...
Peter
Veröffentlicht : 08/07/2016 2:24 pm
