Prusa Support, Echat, excellent
I had a heatbed thermal runaway today on my Mk3, followed by preheat errors as the heat bed failed to heat.
I checked what I could, and proposed a failed power wire in the heatbed cable bundle.
I contacted Prusa support via echat, and 'Ondrej' confirmed my diagnosis, and promised to send a replacement heatbed in tomorrow's deliveries, all within 19 minutes...
this was excellent service.
Opublikowany : 19/02/2018 1:10 pm
BillC
(@billc)
Re: Prusa Support, Echat, excellent
Joan,
I know exactly what you mean. I had a problem on 12 Feb with my second Mk2S and used echat to discuss it with Peter. Almost immediately diagnosed and confirmed as a faulty thermistor. The replacement arrived in rural Philippines today.
Helpful attitude, polite and efficient service - I give Prusa echat team 11 out of 10.
Bill
Tagaytay City, Philippines
Opublikowany : 19/02/2018 4:33 pm
Despite UPS couriers best efforts to muck up my delivery, the parts were dropped off at a collection point Yesterday... UPS just didn't bother telling me...
[attachment=2]20180223_203912[1].jpg[/attachment]
this is what happenned to my heatbed! caused by flexing of the cable loom, and stiffness of the power cables
[attachment=0]20180223_200218[1].jpg[/attachment]
the replacement parts included a replacement heat bed, with revised cable grip, to reduce cable flexing at the heatbed connections.
I refitted the new parts and my printer is back in service
[attachment=1]20180223_204530[1].jpg[/attachment]
the wires on the left are the standard Prusa power cables, they have a higher than average conductor count (approximately 22 individual strands in the bundle rather than 7 in a less flexible cable) I would rather use wires like on the right, these are flexible silicone rubber insulated wires, with 252 individual conductors and a current rating of 22Amps, which should be adequate for the job
Opublikowany : 23/02/2018 11:47 pm
Greg
 Greg
(@greg-8)
Have to agree - all those folks should get an extra ration of gummy bears !!!
Opublikowany : 25/02/2018 6:57 pm
thrawn86
(@thrawn86)
agreed, my bed wires snapped as well and I replaced them with 16ga silicone wire from amazon.
I almost would rather have some sort of terminal block on the bed itself, soldering on it is a huge pain.
Opublikowany : 01/03/2018 8:32 pm
Agreed Curtis, soldering these wires on is a bit of a beast
mind you, a decent soldering iron makes the task easier
Mine is an old 50 watt temperature controlled soldering iron with a chunky bit
I wouldn't even try a 10 watt antex soldering iron,you would be more likely to damage the PCB than solder the wires...
Opublikowany : 01/03/2018 11:08 pm
