Prusa i3 mk2s Z wobble
Padnik
(@padnik)
Hi folks,
Can you guys tell me if this artefacts could be related to Z-Wobble?
As you can see it is appearing only at the bottom.
I noticed that the threaded rods are wobbling around when the x carriage is at the bottom, when the x carriage is further upwards, the z threaded rods are stabilizing itself.
The threaded rods also wobble when there is no x carriage attached at all.
Temp issues are out of the way, as PID calibration is done, and printed in few temp settings from the lowest possible temp to higher ones for PLA and everywhere is the same issue.
Is there any solution to center the threaded rods again? I don't know if it is even possible, because the rods are integrated into the motor? Or do I need to ask the support for new Z motors? 🙁
Opublikowany : 04/10/2017 3:26 pm
