Problems with Prusa - nozzle temp. Warranty?
mikhail.k
(@mikhail-k)
I bought printer at prusa3d in december, and first 3 weeks all works fine at 210C
In January i have write your about my problem, for the same PLA filament i need put temp to 240C
I try to “ disconnecting and then reconnecting the power cables to the extruder on the RAMBo board” how your support say me.
Nothing.
Ok i print once a week with 240C ….
But now in april i need to set 255C for fine prints.
All PLS rolls from Prusa3D shop.
I have different colours and for all rolls i need setup 255C.
Could you repair my printer?
What about warranty?
Publié : 08/04/2016 11:27 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Problems with Prusa - nozzle temp. Warranty?
Hi Mikhail
That sounds like a thermistor issue, but it could be something else (nozzle blocked, or PTFE tube damaged).
Can you do a nozzle clean as per the instructions here (from step 3): https://ultimaker.com/en/resources/149-atomic-method
You will have to undo the screws holding the bearing which pinches the filament against the drive gear first.
Can you then please post a photo of the filament after you have pulled it out.
Thanks
Peter
Publié : 08/04/2016 11:35 am
Josef Průša
(@josef-prusa)
Membre Admin
Hi Mikhail,
we thought everything was alright as you didn't reply to our latest email from jan 26th.
Anyways, I see you already sent us a picture thru email this time, and the problem is most likely damaged PTFE tube. No worries, you are covered by warranty and I see Greyson already replied to you.
You can also check if the PLA is really PLA, in last two months I have seen two or three spools mislabeled :-/ PLA won't dissolve in acetone.
BTW: Always, if you believe you have a defective part, send us an email directly. This is true for everyone. It is also mentioned in !!! Before you ask ... Troubleshooting VIDEO! http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video--t472.html
💡 If you have defective part, always contact us at [email protected] directly.
Founder and owner / Majitel a zakladatel
Publié : 08/04/2016 1:12 pm
