Problem with the z axis assembly
Hello,
On of the black caps you have to put on the treaded rods of the z motors is not wide enough.
One goes very smooth. When I me sure them that one is 8.3 mm, the other is only 7.6 mm.
Any suggestions?
Postato : 18/02/2017 2:18 pm
Re: Problem with the z axis assembly
It is not necessary to put them on. Their only function is to protect top motor bearing from dust. Assemble the printer, make it calibrated and working and later you can print the caps yourself.
Postato : 18/02/2017 6:36 pm
