Prints have stopped!
provenzanodj
(@provenzanodj)
Yesterday two prints have stopped without cause
I do not know why it had never happened!
I noticed a possible supply problem.
I attach images. 😯
Napsal : 16/02/2016 3:24 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Prints have stopped!
Hi Amerigo
Is that glue in the PSU or have the capacitors leaked?
If it's the latter, you should contact support via the "live chat" facility on the shop pages and give them a link to this thread.
Peter
Napsal : 16/02/2016 3:31 pm
Hofftari
(@hofftari)
So your printer doesn't even power up now? Not sure what it is we're seeing in the images. Are you referring to that white "goo"?
/Sascha
Napsal : 16/02/2016 3:32 pm
PJR
 PJR
(@pjr)
Just checked my PSU which has the same white glue holding the components, so there must be another cause.
I presume the printer is still working; can you print one of the supplied gcode files to see if that works properly?
Peter
Napsal : 16/02/2016 3:46 pm
provenzanodj
(@provenzanodj)
the printers work well
only yesterday two print have stopped
i see the white glue and i ask
Napsal : 16/02/2016 3:51 pm
provenzanodj
(@provenzanodj)
i restarted the same gcode file and they printed..
Napsal : 16/02/2016 3:52 pm
